OX body with belt
gantry is a C beam leadscrew
CBeam OX
Build in 'CNC ROUTER BUILDS' published by peter28, Dec 30, 2016.
i wanted to use both the ox and the C beam C beam for the gantry because its stronger i also made the gantry 20 mm higher so i can cut thinker material i will maybe later go to rack& pinion on the 1500 mm Y axes also instead of the V wheels i will maybe go to hiwin in the furture
Mark Carew likes this. -
Build Author peter28, Find all builds by peter28
