The Flexible Axis Revolving Tool-holder is a spring-loaded, ball bearing precision device which can apply variable force and cut or draw on uneven surfaces. It can be a drag knife, pen holder, plotter holder, and more!
To build this, you need to find a rod which can fit into your spindle collet(mine was 1/4" so I found a 1/4" rod). Then you need a spring which fits around the rod and is of the length and tension which supports your needs and z-axis travel. Finally you need some material for the block which can be drilled and hold it's shape well(I'd prefer aluminium but all I had was plexiglass). Then you drill 2 holes. One is straight through and the other is at 35 degrees. Put the rod through the hole and then hold it in place using c-clips and the spring. then tap another hole perpendicular to the hole at 35deg and insert a set screw to hold your tool.
I was able to use parts from a printer I tore down. I found a plastic collar with a bearing in it that fit the rod perfectly and a plastic washer to keep the spring from snagging the rotating collar. I used my drill press to hold the precision rods while I used a hacksaw to cut the c-clip slots. It has minimal play and a large travel with highly variable force. There's a tiny amount of play in the plastic collar but it won't affect the outcomes significantly.
Build in 'Everything Else' published by The Dude, Feb 7, 2014.
Drag knife and pen holder which mounts in spindle collet.
I would like to extend this by adding a way to lock the rotating parts so I can draw with a calligraphy pen.
hamid salahshour, GrayUK, zolmic and 5 others like this. -
Build Author The Dude, Find all builds by The Dude
I built this because I needed a way to draw on my uneven router table without smashing the pen head. I had also heard about drag knifes and knew I would be needing one so I made a device which does both.
