Here is the start of my build. I am hoping for lots of help with getting the design for a large laser cut table for cutting cloth. This is my first build and I will build a smaller table to get the electronics working and get a feel for how to do this. I will be posting updates hopefully weekly until I really get the project off the ground. Then more often as things really progress.
Any help would be great.
I am not that good with Sketch up but here are my thoughts so far.
Large Laser cut table build
Build in 'Laser Cutter Builds' published by Shannon Jardine, Mar 11, 2016.
Large 6 x 10 foot laser table build. New to building CNC
Rick 2.0 likes this. -
Build Author Shannon Jardine, Find all builds by Shannon Jardine
To help cut out patternsInspired by
Friend that has built a small table -
Qty Part Name Part Link Comments 3 V-Slot linear Rail 20mmx80mmx1500mm http://openbuildspartstore.com/v-slot-linear-rail/ Link 8 T Joining Plate http://openbuildspartstore.com/t-joining-plate/ Link 3 Nema 23 Stepper Motor http://openbuildspartstore.com/nema-23-stepper-motor/ Link 6 Micro Limit Switch http://openbuildspartstore.com/micro-limit-switch/ Link 0 Link 1 GT3 Timing Belt Spool http://openbuildspartstore.com/gt3-timing-belt-spool/ Link 1 GT3 Aluminum Timing Pulley - 20 Tooth http://openbuildspartstore.com/gt3-aluminum-timing-pulley... Link 1 Timing Belt Tension Torsion Spring http://openbuildspartstore.com/timing-belt-tension-torsio... Link 1 12V/30A Power Supply http://openbuildspartstore.com/12v-30a-power-supply/ Link 1 CNC xPRO V2 Controller Stepper Driver http://openbuildspartstore.com/cnc-xpro-v2-controller-ste... Link
