      4.6/5,
      5 votes
      Sometime ago, i've built a small CNC Laser engraver, but it doesn't satisfy me, both the electronics and the mechanical...
      After a while i've started to design a new control board for the Laser, this time i want all the electronics on a single PCB, both the movement control and the current driver of the laser.
      The first step was to design the circuit : I've used the standard GRBL pin assignment, the LT3083 to drive the laser and the stepstick to move the motors.
      NOTE: This is a REV1, I have already identified an improvement to do ...
      Schematics (REV 1):
      PCB (REV 1):
      With these files I have made the PCBs:
      Then I've soldered all the components and this is the result:
      (In the next build i'll use the vslot to build the mechanics)
      Update:
      With the need to generate the GCode for the laser directly from an image, i've started to write an extension for Inkscape (http://www.inkscape.org/).
      Installing:
      Step 1)
      Download from "Attached Files:" (at bottom)
      Step 2) Extract the archive and simply copy all the files in the folder "Extensions" of Inkscape
      Code:
      Windows ) "C:\<...>\Inkscape\share\extensions"
      Linux ) "/usr/share/inkscape/extensions"
      Mac ) "/Applications/Inkscape.app/Contents/Resources/extensions"
      for unix (& mac maybe) change the permission on the file:
      chmod 755 png.py
      chmod 755 raster2laser_gcode.py
      chmod 644 raster2laser_gcode.inx
      Usage:
      Step 1) Resize the inkscape document to match the dimension of your working area
      Step 2) Draw or import the image
      Step 3) To run the extension go to: Extension > 305 Engineering > Raster 2 Laser GCode generator
      Step 4) Play!
        1) This is a REV 1 of the board.
        2) English is not my native language, so sorry for my poor grammar...
      dreiii, yakeen, Alonso Vilo and 16 others like this.
    I've started this project to have a single board for controlling a small Laser cnc
    0 Link
