Figured since I have a bunch of extra parts left over from my last 2 builds I might try to do a Micro Ox just for kicks. I'll make the machine 2' x 2' and see about using an brushless outrunner motor like in Robert Hummels 890KV Ox
http://www.openbuilds.com/builds/890kv-ox-rc-spindle.411/
Plus it will give me a chance to try some of those chinese breakout boards. I'm going to continue to use Mach 3 just for the fact I don't feel like learning yet another piece of software right now and it's simple to set up and use.
I be using the phenolic plates I sell in my webstore. These are the standard REV80 Ox plates that will fit any of the standard Ox builds, only slightly thicker @ .375 (3/8") rather then 1/4". The phenolic plates are a affordable alternative to get started without sacrificing performance. If you would still like 6061 aluminum plates you'll be able to cut a set once your machine is up and running.
www.area51cncparts.com
Check out my other 2 builds here :
http://www.openbuilds.com/builds/area-51-cnc-parts-f-117-cnc-gear-rack-drive-system.1428/
http://www.openbuilds.com/builds/florida-ox-2x4-with-vac-table.1270/
Thanks to Mark Carew for giving us the tools to create some pretty cool machines !!
future_cncist, Robert Hummel and sgspenceley like this. -
Build Author Hytech2k, Find all builds by Hytech2k
Just for kicks and experiment with different parts and electronics available -
