OpenBuilds C-beam inverted Y axis 15mm belt on 1500mm C-Beam. Rather than use 3mm 5mm or 10mm belt I chose to use 15mm polyurethane steel belt. Adapting the PRUSA i3 belt drive Y axis method to the OpenBuilds C-Beam.
OpenBuilds C-beam 15mm belt on 1500mm C-Beam.
Build in 'CNC ROUTER BUILDS' published by Dave420, May 18, 2016.
you will want to shave/grind the two 6m bolt heads so they are no wider than 6mm. this will allow them to sit in the track without touching anything. like a T bolt. I also tapped the giant plates and put lock nuts on both sides of the giant plate.
Build Author Dave420, Find all builds by Dave420
because it is better than a 3 or 5mm belt at 1500mm.Inspired by
PRUSA i3 Y axis belt drive.
