I am in the building stage of a CNC rotary axis routing lathe based on the OX CNC Router. My Roto-OX machine will use the X-Axis from the OX CNC router modified to use 20X80 V-Slot instead of 20X60 as I am building the machine 1500mm long. The Z-Axis will use the extended Z-Axis wheel plate recently added to the OX drawings also modified to accept the 20X80 V-Slot rail. I have a Chinese stepper spindle and tailstock which will operate the rotary axis. I am using the TinyG controller board on the Roto-OX. I have posted some preliminary Sketchup drawings of what I am building but am tweaking the design as I go so things will likely change. Check the discussions section to see my latest progress.
Rotary Axis OX Derivitive
Build in 'Other Lathe Build' published by dougsnash, Jan 4, 2015.
A Rotary Axis CNC router based on the OX CNC Router
All information listed here is of a preliminary nature as I have not yet completed this machine.
PaulN, Ronald4418, Wheatabx and 17 others like this. -
Build Author dougsnash, Find all builds by dougsnash
Interested in trying rotary axis CNC millingInspired by
Mark Carew's OX CNC, http://www.openbuilds.com/builds/openbuilds-ox-cnc-machine.341/ -
Qty Part Name Part Link Comments 1 Nema 17 Stepper Motor http://openbuildspartstore.com/nema-17-stepper-motor/ Link Z-Axis 1 Nema 23 Stepper Motor http://openbuildspartstore.com/nema-23-stepper-motor/ Link X-Axis 1 Rotary Axis Spindle and Tailstock Set http://www.ebay.com Link Rotary Axis 1 Gantry and X/Z-Axis Plates Link Custom modified OX CNC plates (See Drawings) 3 20x80 V-Rail (1500mm) http://openbuildspartstore.com/v-slot-20-x-80mm/ Link Main X-Axis and A-Axis supports 3 20x40 V-Rail (1500mm) http://openbuildspartstore.com/v-slot-20-x-40mm/ Link Additional Support Rails 8 Cast - 90 Degree Corner Bracket http://openbuildspartstore.com/cast-90-degree-corner-brac... Link Support angles 16 OpenBuilds Xtreme Solid V Wheel Kit http://openbuildspartstore.com/openbuilds-xtreme-solid-v-... Link Could also use the stadard wheels 8 Eccentric Spacers http://openbuildspartstore.com/eccentric-spacers/ Link Adjust wheel tension 30 Precision Shims http://openbuildspartstore.com/precision-shim-10x5x1mm/ Link Used primarily with wheel kits 2 Spacer Block http://openbuildspartstore.com/spacer-block-v-slot/ Link Used for Z-Axis wheels 1 Tee Nut (25 pack) http://openbuildspartstore.com/tee-nuts-25-pack/ Link Used throughout build to fasten parts to the V-Slot rail 15 5mm nylock nuts http://openbuildspartstore.com/nylon-insert-hex-locknut/ Link Used on cast aluminum angles and on X-Axis wheel bolts 1 15mm M5 Low Profle Screws (25 pack) http://openbuildspartstore.com/low-profile-screws-m5/ Link 1 30mm M5 Low Profile Screws (10 pack) http://openbuildspartstore.com/low-profile-screws-m5/ Link Used to mount the wheels to 1/4" plate (replaces the 25mm bolt in the wheel kits) 1 8mm M5 Low Profile Screws (25 pack) http://openbuildspartstore.com/low-profile-screws-m5/ Link Used throughout build 1 20mm M5 Low Profile Screws (25 pack) http://openbuildspartstore.com/low-profile-screws-m5/ Link Used to attach the V-Slot Rail to the end plates 6 1/4" Aluminum Spacer http://openbuildspartstore.com/aluminum-spacers/ Link Additional wheel spacers 4 65mm M5 Cap Screw Link X-Axis bolts, source locally or from McMaster-Carr 3 45mm M3 Cap Screw http://openbuildspartstore.com/m3-cap-head-screws/ Link Support bolt for Z-Axis stepper 1 8mm ACME Threaded Rod http://openbuildspartstore.com/8mm-metric-lead-screw-acme/ Link Z-Axis threaded rod 1 8mm ACME Nut Block http://openbuildspartstore.com/8mm-lead-acme-nut-block/ Link Z-Axis 3 1-1/2" Aluminum Spacer http://openbuildspartstore.com/aluminum-spacers/ Link Z-Axis stepper motor support spacers 2 NEMA 17 Threaded Rod Plate http://openbuildspartstore.com/threaded-rod-plate/ Link Z-Axis plates 2 8mm Bearing http://openbuildspartstore.com/688z-ball-bearing-8x16x5/ Link Support bearing for Z-Axis threaded rod 2 8mm Locking Collar http://openbuildspartstore.com/lock-collar/ Link Bearing retainer lock collar for Z-Axis threaded rod 1 5mmX8mm Flex Coupling http://openbuildspartstore.com/5mm-8mm-flexible-coupling/ Link Z-Axis threaded rod to stepper motor coupling. Use appropriate sized coupler if using other than NEMA 17 Z-Axis motor 4 1/8" Aluminum Spacer http://openbuildspartstore.com/aluminum-spacers/ Link Used on X-Axis motor to keep step on motor clear of mounting plate 6 GT3 Timing Belt http://openbuildspartstore.com/gt3-timing-belt-by-the-foot/ Link X-Axis drive belt 1 GT3 Timing Pulley http://openbuildspartstore.com/gt3-aluminum-timing-pulley... Link X-Axis drive belt pulley 1 20X60 V-Slot Rail x 500mm http://openbuildspartstore.com/v-slot-20-x-60mm/ Link Z-Axis rail 1 45mm M5 Low Profile Screws (10 pack) http://openbuildspartstore.com/low-profile-screws-m5/ Link Z-Axis wheel bolts 0 Link -
