You'll need:
3 x 2020 V-Slot® Linear Rail
3 x 90 Hidden Tee Nut - MAKERLINK (10 Pack) (Don't want to use Makerlinks? See The Almost Perfect 3 Way Mitre (with Angle Corner Connectors) instead)
Cut your V-Slot ends to 45 deg, then turn to an adjacent side, and make another 45 degree cut, ensuring the same distance from the end (a stop-block on the other end of the rail helps a lot!). The more precise you can line up the two cuts, the better the resulting mitered corner will look once complete
Insert two of the 90 Hidden Tee Nuts into them in the way shown below
Add a second rail, and add the 3rd 90 Hidden Tee nut as shown
Note how that second 45 degree cut opens up the corner, to allow the 3rd rail to fit into the Miter
Insert the 3rd rail into the corner
Tighten all the T-Nuts after spending a couple seconds ensuring all the edges of the Miter lines up as best as they can
This is the result:
If you end up using this method to make a mitered corner in one of your builds, let me know in the Discussion tab! Would love to see it!
The Almost Perfect 3 Way Mitre (with MakerLinks)
Build in 'Everything Else' published by Peter Van Der Walt, Apr 6, 2017.
A quick and easy way to make a 3-way mitered corner using MakerLinks
I am a Cat. Just Cat, Bart_the_Builder, Mani R and 6 others like this. -
Build Author Peter Van Der Walt, Find all builds by Peter Van Der Walt
Qty Part Name Part Link Comments 3 90 Hidden Tee Nut - MAKERLINK http://openbuildspartstore.com/90-hidden-tee-nut-makerlin... Link 3 V-Slot® Linear Rail 20x20mm http://openbuildspartstore.com/v-slot-linear-rail/ Link
