      This build is a small timing belt drive setup designed for CNC linear motion testing and light automation applications. The goal is to compare belt tension, pulley alignment, tooth profile selection, and motion stability in a simple belt-driven axis.
      The setup can be used as a reference for CNC routers, 3D printers, engraving machines, desktop automation projects, and other motion systems where a timing belt is used to transfer movement from a stepper motor to a linear axis.
      Main design points:
      1. Belt selection
      A timing belt should be selected according to load, speed, positioning accuracy, pulley diameter, and available installation space. GT, HTD, AT, and T tooth profiles are commonly used in motion systems, depending on the application.
      2. Pulley alignment
      Correct pulley alignment is important for reducing belt wear, noise, vibration, and uneven movement. Misalignment may cause the belt to run against the flange or wear on one side.
      3. Belt tension
      The belt should be tensioned enough to prevent backlash or tooth jumping, but excessive tension can increase bearing load and shorten belt life.
      4. Belt material
      Rubber timing belts are often used in industrial transmission systems because they provide stable operation, flexibility, low noise, and good vibration absorption. PU timing belts may be considered for applications requiring higher dimensional stability or cleaner operating conditions.
      5. Application environment
      Dust, temperature, oil, machine duty cycle, and repeated acceleration or direction changes can all affect belt performance and service life.
      This simple belt drive setup is useful for observing how different belt widths, pulley sizes, and tensioning methods influence CNC motion performance.
      Rubber timing belt technical reference
      Rubber Timing Belt Manufacturer | Synchronous Drive | Conxu
        This build is intended as a general reference for belt-driven CNC motion systems. Final belt selection should be based on actual load, speed, pulley size, installation space, and operating environment.
    The purpose of this build is to create a simple reference setup for testing timing belt performance in CNC linear motion systems. It helps compare belt tension, pulley alignment, tooth profile selection, and motion stability before applying the belt drive to a larger CNC or automation project.
    Inspired by common CNC router, 3D printer, and small automation machine belt drive structures.
