This is a small system of 3d printed parts you use in combination with the V-slot for your project to cut your extrusion pieces down to length, with lock downs for repeatable cuts to the same length within a 1mm each cut.
V-Slot Cutting System
Build in 'Everything Else' published by Kyo, May 12, 2015.
A System of 3d printed parts to use along with your projects aluminum extrusion to cut your pieces of v-slot to length manually.
Bruce Howard, IronKane, jlipavsky79 and 3 others like this. -
Build Author Kyo, Find all builds by Kyo
I needed a way to cut my 20x20 and 20x40 to a repeatable length as accurate as possible with no vise and no power tools. -
