DIY CNC Machine
Discussion in 'CNC Mills/Routers' started by BooTec, Jun 8, 2019.
Thread Status:
Not open for further replies.
  1. Amadiro
    Amadiro New
    still unsure as to some of the electronic wiring
    1. There are 2 green/blue wires coming off the enable pin on the CNC shield not sure where they go.
    and
    2. What are these connections at 2
  2. Joren Meesters
    Hi, I really like the way you build this machine and I'm interested in building it myself.
    Do you have any plans (CAD or PDF) to share with dimensions for the rails etc?
    Thanks in advance!
  3. OnlyNoly
    OnlyNoly New
    Hi Bootec,
    Very nice job,
    Could you please share the CAD drawing file.
    Thanks.
  4. Giarc
    I think all he did was come here and post it then leave. He hasn't been back for over 24 weeks. He says how to figure out how to reconstruct it from the video here DIY CNC Machine but if you look at post 30, you will see he sells the plans so it is not opensource.
  5. OnlyNoly
    OnlyNoly New
    Thanks Giarc, I was after the CAD drawing files but I guess I'll have to settle with the video and plans
  6. Tuoman
    Tuoman New
    CNC shield "GND"------------->TB6600 "DIR-"
  7. ColinJ
    ColinJ New
    Could I please have a copy of your plans.
  8. Giarc
    They are not opensource. He sells them.
  9. Pierre Smit
    Is it possible for me to obtain the cad files also?
  10. JustinTime
    I have built a very similar machine. The only thing that required some planning was the Gantry plates. Every thing else I did on the fly depending on the space I have or the size of the material I wanted to cut. I had bought on AliExpress the linear rails and ball screws and then build the machine to accommodate these.
  11. Pierre Smit
    Thank you. Good advice.
  12. geniculata
    Hello,
    Can you please share your cad drawing with me too?
    Thank you very much.
  13. Pierre Smit
    He did not reply to my request. I am following the advice of "Justin Time"
Thread Status:
