first CNC build
Discussion in 'CNC Mills/Routers' started by Kelly Horn, Feb 6, 2021.
  1. Kelly Horn
    Kelly Horn published a new build:
  2. Kelly Horn
    Hello all
    I had a lot fun making my router. Now I got find a CAM program. For 2.5D I have been using CorelDraw
  4. Kelly Horn
    thanks Peter, I will take a look
  5. JustinTime
    Kelly, why did you use a timing belt and why is it so long? Is it feeding two ball screws?
  6. Kelly Horn
    Yes it is feeding 2 ball screws
  7. Kelly Horn
    Just received the new linear ball bearing for the Z axis and it had more slop than the old washing machine bearing. Does any one know a good type bearing?
  8. JustinTime
    Don't they have a screw on the side to adjust the slope?
  9. Kelly Horn
    I will have to check thanks
  10. Kelly Horn
    just checked. it is fixed no, screws
    #10 Kelly Horn, Feb 9, 2021
