V1.0.283 Error when probing
Discussion in 'Control Software' started by MIke Antonacci, Feb 11, 2021.
Tags:
  1. MIke Antonacci
    Hi, Control software updated today to v1.0.283.
    Now when probing for Z 0 I am getting and error. The bit slowly heads to the probe and stops when it touches then I getting an error message that displays in a pop-up.
    It reads:
    error: 3 - Grbl '$' system command was not recognized or supported. [ $J=G91G21Z5F1000 ]
    Incase you wanted to look at the log here it is.
    15:15:47] [ G21 ] ok
    [15:15:47] [ G10 P1 L20 Z0 ] ok
    [15:15:53] [ [ PROBE ] ] Probe Completed.
    [15:15:53] [ G38.2 Z-25 F100 ] [PRB:-478.965,-580.119,-32.298:1]
    [15:15:53] [ G38.2 Z-25 F100 ] ok
    [15:15:53] [ JOB COMPLETE ] Job completed in NaNh NaNm NaN.NaNs / Probe Complete: Remove the Probe Clip and Probe Plate before continuing...
    [15:15:53] [ G4 P0.4 ] ok
    [15:15:53] [ G10 P1 L20 Z19.79 ] ok
    [15:15:53] [ ] error: 3 - Grbl '$' system command was not recognized or supported. [ $J=G91G21Z5F1000 ]
    [15:15:53] [ ERROR ] error: 3 - Grbl '$' system command was not recognized or supported. [ $J=G91G21Z5F1000 ]
    [15:15:53] [ $J=G91G21Z5F1000 ] error:3
    [15:16:03] [ ALARM ] ALARM: 3 - Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended. [ undefined ]
    [15:16:03] [ ] ALARM: 3 - Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended. [ undefined ]
    [15:16:03] [ ] ALARM:3
    [15:16:04] [ ] Grbl 1.1g ['$' for help]
    [15:16:04] [ ] [MSG:'$H'|'$X' to unlock]
    [15:16:05] [ $$ ] $0=10 ;Step pulse time, microseconds
    [15:16:05] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [15:16:05] [ $$ ] $2=0 ;Step pulse invert, mask
    [15:16:05] [ $$ ] $3=1 ;Step direction invert, mask
    Thank you for your help with this.
    Mike
  2. sharmstr
    Peter. Just came in to tell you the same thing. None of the retracts are working during probing. The command is being sent, but machine doesnt move. Actually, Z probe does sometimes. I have a video I can post, but I'm sure you can test as well. I rolled back to .282 and all is well.
    #3 Peter Van Der Walt, Feb 11, 2021
  4. sharmstr
    Should mention that I rebooted and reset BB and still had issues I've tested XYZ, Z and X. Again, Z works sometimes. XYZ finds Z then drags the bit across the probe plate. X probes but doesnt retract. DRO reads 13 as it should but bit is actually at 3 since it didnt move.
    Bug confirmed, found and fixed - v1.0.284 will be with you shortly :)
  6. sharmstr
