cam gcode path problem
Discussion in 'OpenBuilds Forum Help' started by calou, Dec 31, 2020.
  1. calou
    calou New
    Hello recently I have a workbee for plasma cutting, with openbuilds control and cam I opened a clean dxf file a realization with 126 holes of all shapes when I generate the code there is a multitude of lines in all directions. Not too logical and the starting points of all lengths set to 4mm and red lines that cross. Cam and 'its limit? Or I made programming errors,
    Thanks for your help
    For full control over ordering, create seperate toolaths. (takes a few seconds more set up time than a Select All, but saves cut time)
    CAM follows the order the entities appear in the file, as well as the order the points inside the vector its given is already is ordered.
    Fancier CAM softwares of course has algorithms to optimise it for you
  3. calou
    calou New
    Hello and happy new year, I will come back to you, I did with less distance and I always have starts of all lengths, I have another problem on the workbee I have a floating Z when I create the gcode with the Z0 a trajectory, but the Z rises more to change parts if I, put the Z4 so that it rises the trajectories are double, I am in the position with touch off. I manage to cut I'm afraid of collision with each change of parts, I can't find the errors that I had to make THANKS for everything.
    Is your Z moving more than commanded? Did you calibrate Z steps per mm yet?
  5. calou
    calou New
    yes I have calibrated the steps of Z in mm
  6. calou
    calou New
    Hello i tried everything looked at everything and every time plasma click touch off zero( yes) the drawing always splits I opened openbuilds cam with Microsoft Edge and Google Chrome it doesn't change anything, there is a software problem i don't have to not be the only one having this kind of concern.
    Can you explain or show what you mean by that?
  8. calou
    calou New
    I don't understand I'm not the only one to have this problem I apologize for the English I'm French
  10. calou
    calou New
    I send you the dxf tell me the errors and send me the gcde thank you.
    Works fine for me: OBC file attached (File, Import Workspace to open it inside CAM)
    - EXTRA: I created the tiny holes as INSIDE cuts, flower shape as OUTSIDE cuts (as I assume you want to small circle as a hole, thus INSIDE cut)
  12. calou
    calou New
    program like me
    Don't use G92. The touchoff sequences is JUST a probe.
    DO NOT SET any positions, CAM sets that for you using the correct G10 commands
  14. calou
    calou New
    Hello, always the same problem when creating gcodes with openbuilds cam .
    Those are Lead-in's on a Inside path. If you don't want to use Lead-in, set distance to 0.
  16. calou
    calou New
    If I set to 0, the piercing point makes a mark on the cut I don't, it's no longer what to do.
    Thats the point of a lead-in, to avoid the pierce mark on your cut edge. If its an inside cut, we pierce inside the waste cutout. How long it is, doesn't really matter, that is a waste piece
  18. calou
    calou New
    It's all the interior cuts that I have this concern if I don't move away from the starting point it makes a mark, give me an example.
  19. Peter Van Der Walt
    @calou and @Dennis Langhoff and @IanCaz , i've pushed some testing code that may help - sorting the lead-in paths offset vector to find the point closest to the actual starting point of the cut vector, and injecting that point directly in front. Give it some testing and let me know if it improved the situation for you.
    Remember to force-refresh your browser to get the latest code running (Ctrl+F5, Shift+F5)
  20. calou
    calou New
    Hello, I'm sorry, I didn't understand anything, is it possible to have an example
