OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    OpenBuilds CONTROL 1.0.295 is getting released today, and it, along with its earlier versions the last couple weeks, contain a bunch of cool new features! Find some of the major highlights below:
    1) 3D Viewer now supports on the fly switching between Inch/mm Mode
    Before, only the Gcode you loaded could switch the viewer. Now, the Viewer switches between mm/inch along with the DRO when you click the mm-mode/inch-mode tabs above the DRO.
    _______________________________________________________________________________
    2) Ability to both Go To, and Set coordinates by typing into the DRO:
    Click on the X,Y or Z digital read-out, and enter a new number. If you press [enter] the machine will jog to that position. If you press [shift+enter] the current position where the machine is, is set to the number entered. Useful for fixing Z zero or dialing in offsets for duplicating a workpiece and many other uses
    3) Jog Speed Slider:
    Gone are the days of typing in a Jog speed, when Grbl anyway overruled you most of the time based on its Max-rate configuration. The number input field has now been replaced with an easy to use and easy to understand slider! This solves a couple different issues
    • Allows Z to jog at a different rate than XY: In your Grbl Settings, Z Max Rate can be (and usually is) set lower. This now jogs at a "percentage" of the Grbl Max Rate - so effectively each axis speed is governed by its Max Rate value
    • It is consistent with OpenBuilds Interface - we implemented the Percentage method there and had great feedback from beginners and pros alike as its easier to grasp and use.
    • It is more accurate - because it knows what your Grbl settings dictate the maximum feedrate can be. Before you may have entered 5000mm/min, but Grbl has X Max travel set to 2500. You think you are jogging at 5000mm/min, but Grbl was governing the top speed to 2500 anyway. As its a percentage of the configured parameter, 50% really is 50% of the maximum configured for that axis.
    4) MacOS Big Sur support: Fully Signed and Notarized
    Mac users can now install CONTROL easier than before, because the application and installer is now Signed and Notarized with proper Apple Certificates. No longer do you need to go and allow the application from Settings>Security - MacOS will only prompt you once whether you want to allow the application to open the first time you run it.
    5) Duplicate Key Checking for Keyboard shortcuts
    CONTROL now checks if the key you are trying to assign as a Keyboard Shortcut or Macro shortcut is already in use :
    and also in Macros editor:
    6) Actual Feedrate in Overrides
    This little readout below the Feed Override Slider displays the current maximum actual feedrate the machine is moving it. This is a good number to note down if you use the Feed Override slider to tweak your cutting recipes, knowing how fast the machine is moving when the job is cutting at its best, will help you set up your toolpaths with better feedrates dialed in from the start.
    7) Ability to Backup and Restore your Grbl Settings
    Allows you to export a copy of that meticulously tuned Grbl parameters for safe-keeping
    8) Javascript Macros, that can even start automatically.
    Advanced tweaks, your own wizards, or clever macros that can do a little processing of their own. Your mind is the limit.
    9) Just a reminder how to switch between Inch and MM modes:
    Not new, but something many people haven't noticed yet: Click the Tabs to switch between Inch/mm mode for jogging. GCODE files have their Mode set by your CAM however and overrides whatever this view is set to, because the GCODE contains its own G20 (inch) or G21 (mm ) Modal commands. The 3D view will however attempt to show it at the correct scale.
    10) Review the FULL changelog!
    The detailed Change Log at OpenBuilds/OpenBuilds-CONTROL lists every little bugfix, new feature, and change made to CONTROL, so do keep an eye on it occationally :)
  2. DarkPenguin
    DarkPenguin Well-Known
    When the job done dialog pops up one might expect that hitting space would dismiss the dialog. One would be wrong as that dialog just sits there looking at you while the job starts again.
  3. sharmstr
    Enter dismisses it. Space starts and pauses jobs unless you've changed that in Customize Keyboard Shortcuts in the Wizards menu.
  4. DarkPenguin
    I know. But that is kind of at odds with how those things usually work. I would expect it to be modal and not just appear to be modal.
    For all the hate the Job Complete window gets, i guess its just time to remove it. Next version :)
    #1775 Peter Van Der Walt, Mar 24, 2021
  6. sharmstr
    Can you print log it? Because I do find the information useful.
    For sure. (; and will store it for use with Macros, got an idea for an Invoicing macro
  8. sharmstr
    I like the sound of that!
  9. JustinTime
    Can it be put in a permanent cell somewhere on the screen rather than a pop-up window?
    I will soon. I'm now deep in alligators doing another job and the machine sits ideal. I already go an email from it's lawyer complaining of neglect. :)
    So the "job complete" popup is gone, and the data is stored in Localstorage (for future Macro use)
    but also added a simple log under Wizards and Tools > Job Log
  11. sharmstr
  12. Flyinb
    Flyinb New
    OK i downloaded and installed the control software no problem. when i start the program nothing shows up but task manager says it's running, am i missing something? Running it on a windows 7 desktop to check it out. Thanks, Bruce
  13. David the swarfer
    it iconizes to the taskbar, just click the icon there to fullscreen it
  14. Ronald4418
    Ronald4418 Well-Known
    I'm not sure which section this goes in other than it involves the latest update. Whenever I Home All, it goes through the standard routine of Raising the Z-Axis to the Home Switch and the same for the X-Axis. But when it Homes the Y-Axis and then moves to the Offset Distance after contacting the Y-Home Switch, it repeats the Y-Homing Sequence but disregards the Y-Home Switch and Jams up my Y-Axis. I am running a C-Beam XL with only a Single Y-Axis Drive.
  15. DarkPenguin
    Get out your multimeter and check your wires.
    Agreed, nearly impossible to be CONTROL related. Wiring most likely, or Grbl settings
  17. Flyinb
    Flyinb New
    No icon appears on taskbar but what does happen is when i start control a small popup appears on the right side of the task bar then goes away, it says "Open builds Control has started active on 10.0.0.4:3000) ? I go to task manager and says it running.
  18. Ronald4418
    It happens regardless as to the GRBL Firmware that I am running, be ir OpenBuilds Controller or any of the others that are available. Be it SharpCNC, OpenBuilds, or plain Jane GRBL 1.1f.
  19. Ronald4418
    If it were wiring it wouldn't recognize the original Y-Axis Home Switch.
  20. DarkPenguin
  21. Ronald4418
    I'm inclined to think now that the Offset after hitting the Home Switch isn't large enough. The Switches seem to need more than a 20 mm Offset after being triggered.
  22. Peter Van Der Walt
    What switches do you have?
    Could also just be noise on the signals, are you using filtering?
  23. Ronald4418
    Here is a picture of my Home Switches,
  24. Peter Van Der Walt
    Fair enough those are overkill and probably do need a massive pull-out distance
    do include details like that when you ask about related problems :) would help avoid guesses based on assumptions of default components.
  25. Alex Chambers
    There is a tab on the taskbar for "hidden icons" - it's in there.
    Alex
  26. Peter Van Der Walt
    After a reboot, CONTROL sits waiting in the system tray. Launch it from either:
    • Desktop icon
    • Start menu
    • System tray icon
    • Integrations (OpenBuildsCAM, SketchuCam and (soon) Fabber)
    Once its running in the background, any of the above launches the UI
  27. Flyinb
    Flyinb New
    There are several icons visible on the right of the task bar but open builds is not on of them, i do have the control icon pinned to the task bar as well, when i hit it to open the app that little popup right above all the icons says "Open builds Control has started active on 10.0.0.4:3000", what ever that means. Not new to computers and did build a cnc plasma cutter years ago so not a real newbie but heck i am getting older.lol. There is no UI at all showing up. Do you know what that "active on 10.0.0.4:3000" is all about.
  28. DarkPenguin
    It should mean that it is running and listening on IP 10.0.0.4 port 3000. Bring up a browser and load http://10.0.0.4:3000/
  29. Peter Van Der Walt
    Which is just another way to access the UI. Dont use this as your primary way either..
    If the UI doesnt come up, try a different PC
  30. DarkPenguin
    It's an easy method to confirm it is running.
