dumb question
Discussion in 'CNC Mills/Routers' started by Tony Lavalle, Aug 5, 2021.
  1. Tony Lavalle
    for the spindle on the lead 1010 CNC, am I supposed to cut the plug and wire it to the power supply or here's the dumb just plug it in the wall? I know its a dumb question but i had to ask.
    The Router (Spindle) needs mains power, plug into the wall, or via an IoT relay docs:blackbox:connect-dewalt-iotrelay [OpenBuilds Documentation] if you want to control its on/off from software (Without the IoT you have to remember to start it before clicking Run, and turn it off once the job is finished)
    The PSU is 24v DC and only powers the Blackbox: See docs:blackbox:connect-psu [OpenBuilds Documentation]
