What is the exact space for a mini wheel carriage on an 2040 extrusion?
Discussion in 'General Talk' started by Pascal 3DJunkie, Dec 2, 2021.
  1. Pascal 3DJunkie
    i want to make a z-carriage with mini wheels for a 3d printer.
    What is the exact space between the wheels center to roll on an 2040 aluminium extrusion?
    See picture in the attachment. i mean the distance for the red line.
    Are mini wheels ok for a z-axis or the big wheels better?
    Thank you for help.
    Pascal 3DJunkie likes this.
  3. Rick 2.0
    ^^^add 12mm to the extrusion width for mini wheels. 20mm for full size wheels. And as Peter notes you’ll need eccentric spacers along 1 side of the plate to account for manufacturing tolerances.
  4. Pascal 3DJunkie
    Thank's for the fast answer.
    What do you mean with the 12mm?
    i have calculated that the space between the center of the wheels for an 2040 extrusion is 50mm.
    I know i must use one eccentric spacer. See Attachments.
    Do you think that the mini wheels are good for this or that big wheels are better?
  5. Rick 2.0
    If you’re using stock OpenBuilds parts the dimension would be 40 (for the extrusion) + 12 (for the wheels) = 52mm.
    It’s always a good idea though to do a mock up and a test fit. Can’t go wrong that way.
  6. Pascal 3DJunkie
    Thanks to all. learned something again.
    Mark Carew and Giarc like this.
