Where is config.h located for access?
Discussion in 'General Talk' started by Larry Paige, Dec 3, 2021.
  1. Larry Paige
    I am trying home x and y in 1 cycle as shown on the internet, but cannot find access or location of the config.h file using Blackbox. Please help.
  2. sharmstr
    Not exactly sure what you mean by x and y in one cycle, but if you want to have a custom grbl config, then you need to compile it yourself. Here's how: Compiling Grbl · gnea/grbl Wiki
    Once you have your custom firmware compiled, you can use Control to upload by going into Wizards and Tools -> Firmware flashing tool.
    Be careful and follow the directions. Lots of people screw it up.
  3. Larry Paige
    I appreciate you!
    If its an advanced, custom homing sequence you are after, you'll have to compile yourself
    But if its one of the more standard, popular things, we provide a couple different precompiled options directly in the Wizard (For example, if you mean ONLY XY homing for a Laser - ie No Z axis - we have the 2axes option right there in the wizard; Building a plotter and need the Servo feature, it's in the wizard; Want to enable the compile time Door interlock options? It's in the wizard)
  5. Larry Paige
    This is what I wanted to do, but seems too complicated now.
    Grbl already homes Z first, then X and Y together. The word Optional there is just documentation wise. If its uncommented, its active
  7. Larry Paige
    Mine does not do that. All axis are single. Runs X to the limit switch and then it will run Y. I'll poke around and look for something that I may be missing. Thx
    Probably not running stock Grbl already, flashed any 3rd party hex files?
  9. Larry Paige
    No, all stock stuff. I am running 2 C-Beams X & Y. I started off with Acro 1510 and adjusted the limits. for a 1500 and a 1000mm beams. Set t 1300 and 850mm to be safe.
    Thx
  10. Larry Paige
    I see only 2 axes, so you are running the 2 axis firmware not stock Grbl. In which case you have X and Y seperate. Custom recompile then if you want it together yes.
  12. Larry Paige
    gotozero!? Wow, okay I have been using Home expecting X and Y not X then Y. Gotozero does exactly what I needed. Sound like it's working proper? Are you laughing out load yet!?
  13. sharmstr
    You cant rely on go to zero moving to the same place every time unless you home your machine first.
  14. Larry Paige
    Yep, playing with it now. I Home and set all axis to zero and run a project (circle shape). Then, I gotozero and it works properly, but instead of reading 0 it reads the limits as seen below. This should read 0...
  15. Larry Paige
    So, in other words, the machine works fine, but the numbers aren't aligned?
    Not sure what you mean? But read the Grbl Wiki :)
    Homing sets Machine Coordinates
    Setzero sets Work. Coordinates
    Steps per mm sets travel distance calibration
