Motor shaft extension / camera Timelapse slider
Discussion in 'Other Builds' started by PACU, Jan 8, 2022.
  1. PACU
    PACU New
    https://drive.google.com/file/d/1xkvHfgUELyxdR4SBIGBQDutaWTCOMTbI/view?usp=drivesdkHi all,
    im doing my first DIY/open builds project for this camera time lapse slider and everything is taking good shape, however, the motor I got has a shaft that is JUST too short for the rail and the belt rubs against it so I was wondering if there was a way of extending it.
    The motor also has a small thread in the shaft, not sure if that helps, looks like 4 or 5mm.
    The pulley is a 30-tooth from openbuilds.
    Attached is a photo of what I’m describing, from the hole missing the set-screw you can see that the shaft doesn’t go all the way, and that the belt is making contact with the rail.
    p
    Extending is an unlikely prospect, try replacing it with one of our motors
