Lead 1010 wheels lose
Discussion in 'CNC Mills/Routers' started by TheyHey, Apr 13, 2022.
  1. TheyHey
    TheyHey New
    Wheel preload is adjusted using the Eccentric spacers (Typically most people turn the plate so the eccentrics are on top for easier access, but that is your preference - you can still adjust them from below)
    Perfect tension is when the wheel just starts to grip. Set it too tight and the wheels will wear down faster, too loose and the machine will have accuracy issues.
    See
    TheyHey likes this.
  3. TheyHey
    TheyHey New
    Yeah, its it. Thanks bro!!
