Help!!!!!
Discussion in 'CAM' started by dr_chops, Jun 5, 2022.
  1. dr_chops
    dr_chops New
    I’m at a loss as to why when ever I generate code and send it to my machine and press go it drives the torch into the sheet. I’ve watched and followed plenty of tutorial but I’m at a loss as to why. I’m sure it’s something simple but it’s beyond me
    cheers
    Lucas
  2. David the swarfer
  3. dr_chops
    dr_chops New
    Thanks mate I’ll have a crack at that
    cheers
  4. dr_chops
    dr_chops New
    so i tried the z retracted and it turns out that i had it set correctly. here are some photos of what im up to, i dont understand why the model in fusion is on the x/y 0 plane but in the openbuilds controller its in the air?
    Please include the Fusion and Gcode files for further assistance
  6. David the swarfer
    Please use the openbuilds postprocessor docs:software:fusion360 [OpenBuilds Documentation]
    and, from the code (dunno what postprocessor you used) it is doing a probe command to find the sheet, so it is expecting to make a probe connection when it touches the sheet.
    #6 David the swarfer, Jun 13, 2022
  7. dr_chops
    dr_chops New
    thanks david all sorted now thanks mate
