Interface Error
Discussion in 'General Talk' started by TYLER RING, Jun 21, 2022.
  1. TYLER RING
    Powered on my machine and had this error on the interface. I followed the on screen instructions but was not able to overcome the issue. Interface Firmware version 1.51 any help is greatly appreciated. I have a 1515 with blackbox interface and xyz probe.
    1) Make sure you followed all the steps in docs.openbuilds.com/interface chronologically
    2) Also test your BlackBox against a PC - if it also fails to connect its possible your BlackBox is damaged (in which case, go over your wiring and find any shorts)
  3. TYLER RING
    Thank you I am reviewing it now. I’ll let you know if i get it fixed.
