Z depth problem,workbee
Discussion in 'General Talk' started by kajlo30, Jul 23, 2022.
  1. kajlo30
    kajlo30 New
    Hi everyone,i just finished my spindle tram.I surfaced the spoilboard,its flat,no visible toolmarks,looks& feels flat.This is my second surfacing because when i first surfaced the spoilboard it was bad,alot of tool marks because the spindle was not tramed i think.So after all i tried to make a long 500mm single line test cut with the depth of 5mm.At the starting point it was 5mm but at the end it was like 5.65mm in the middle 5.3mm.I checked the 4 corners of the machine and its flat.I made a quick illustration about the situation.
  2. Alex Chambers
    What controller are you using, what are your configuration settings, what spindle/router are you using?
    There are many possible causes of this - we will have to try to eliminate them one at a time. Check that the motor coupler on the Z axis is not slipping.
    kajlo30 likes this.
  3. kajlo30
    kajlo30 New
    Am using a black box controller, the cut was done with 2200rpm,30mm/s and depth of cut 2.5,using a 1.5kw vevor water cooled spindle.
    I will check the motor coupler later today.Thanks for the fast reply!
  4. Alex Chambers
    Check that your $1 setting =255.
    kajlo30 likes this.
  5. kajlo30
    kajlo30 New
    So i made some changes.The motor coupler on the z axis is good.$1 is 255.I re-calibrated all the axis.The x,y axis are perfect.I also tried out something.I made a drilling program.I drilled 3 hole along y axis and the depth of all the 3 holes was spot on! But when i tried to mill a square the depth was off, the dept has to be 3mm.
    Your VFD spindle is heavier than our typical routers (and overpowered for the use case) - so you might be seeing the weight causing deflection How to calculate V-Slot® deflection
    kajlo30 likes this.
  7. kajlo30
    kajlo30 New
    Something is not clear for me,if the x rail is bending while the machine is working than how is my spoilboard flat after surfacing.I mean if there is like 0.65mm diference in depth.There will be noticable lines on the spoilboard or am wrong?
  8. kajlo30
    kajlo30 New
    Today i checked out the x axis profile and its not looking so straight.Also as you can see in my older post,the milling gets deeper on the right side, but i dont get the front to back depth diferences...
    So in tramming, thats why you shouldn't adjust your Spindle - but rather the axis
    1) get the beds XY plane perfectly level (no corner raised or lowered compared to others)
    2) z uprights perfectly perpendicular to Y rails
    3) x rail perfectly parallel to the XY plane
    4) spindle mount perfectly parallel with X rail (in the Y direction its automatically perfectly square to Y because you made sure your Z uprights are square, carriage plates are automatically a fixed reference to a rail
    5) lastly make sure your X rail is not "rolled" where it makes to the Z uprights tilting spindle forward or backward
    Tramming is NOT a spindle adjustment but a "build the machine as square and perfect as possible"
    kajlo30 likes this.
  10. kajlo30
    kajlo30 New
    Thankyou alot sir,i will check everything i can!
  11. kajlo30
    kajlo30 New
    By the way,if i mill a 50x50 square the actual x/y lenght of the square is correct,so i think the y profile is little bit lower one side and its also rolled.
  12. kajlo30
    kajlo30 New
    I checked everything,i found out the machine was a little bit off,but now is square.The x profile in now flat, and not twisted anymore as you can see in the picture.But now the issue is that the z axis cant travel to the left side cause its jaming on the center of the x rail.I measured the x profile with water level ruler and it was ok.Or maybe i cant use the ruler properly...
    A level is a builders tool.
    Use a vernier, or ruler to measure distances relative to other components (same height left and right for example)
  14. kajlo30
    kajlo30 New
    I measured out everything.Spindle tramed.Spoilboard surfaced looks good.But the single line millingtest... the depth is still off.
    Are you measuring the depth relative to the top of the stock?
    If so, did you deck off the stock with a surfacing operation?
    if not - what you are seeing is just standard material deviation - that sheet is not going to be micromillimeter precision thickness all over - its going to have high and low spots
    kajlo30 likes this.
    kajlo30 likes this.
  17. kajlo30
    kajlo30 New
    My Z0 is on the top of the material,and no,i did not surfaced the material...Tomorow i wil surface the top and then i will make a test drill holes and milling.I completly forgott this possibility.
