CAD Model for OB Inside/Outside Corner Bracket?
Discussion in 'CAD' started by Tony LaBelle, Sep 19, 2022.
  1. Tony LaBelle
    Hello - Was wondering if OB has the model available for the Inside/Outside Corner Bracket? I've downloaded and reviewed STEP Part Library 1.5 but it doesn't appear to be there. Thanks in advance for the help/support! :thumbsup:
    Tony.
  2. Giarc
    If its not been posted directly, you can extract it from the Tables OpenBuilds Modular Table Series | 3D Warehouse model where its used to mount the legs
  4. Tony LaBelle
    Will I be able to load into Fusion360? How difficult is it to 'extract' the model from the Table model...new to Fusion360. Thanks for the support.
  6. Tony LaBelle
    Im sorry to be a pain but I don't use SketchUp...is there a version for Fusion 360...or can F360 read SketchUp models?
    Yes!
  8. Tony LaBelle
    Yay!!! Thanks abunch for the awsome support!! :thumbsup:
  9. Tony LaBelle
    Well, according to the author of the above video, it looks like personal license doesn't support this file type...:jawdrop::banghead: I'll give it a try and see if that's the case.
  10. sharmstr
    Unless you're going to be milling it out, why do you actually need it? If its merely for aesthetics its easy enough to model it in fusion yourself.
