Goto XYZ zero
Discussion in 'Interfaces' started by BeeAMaker, May 24, 2021.
  1. BeeAMaker
    BeeAMaker Well-Known
    Haven't checked updates lately, don't always have WiFi in my shop so hopefully this was addressed.
    Hitting "Go to X,Y,Z, Zero" ignores CANCEL.
    I know this is my fault but I would really like to be able to cancel this command. I have hit it by accident 3 times now and broken bits. Two of these times I had time to hit cancel, but not time to reach the black box.
    The button is just close enough to the edge that my fingers hit it when gripping the interface the center with one hand. I have been trying to train myself to pick it up more carefully.
    Daniel Jackson likes this.
    Known bug, but also hard to handle, as its such a short move its "done" before it started basically.
  3. Daniel Jackson
    is there a way to change the order, say do X/Y then drop down for Z?
    Each axis has its own Gotozero option yes. Do them individually if the default does not suffice. Alternatively use the Macros tab for even more control
  5. Daniel Jackson
    sorry this is on the interface module, i hit button accidently, as was wondering if there was a way to swap how it is moved.
    #5 Daniel Jackson, Sep 24, 2022
