Y axis travel distance off. How to Fix?
Discussion in 'CNC Mills/Routers' started by jda70az, Oct 13, 2022.
  1. jda70az
    jda70az Well-Known
    Hi.
    Hoping you guys can help me.
    What is the calculated steps/mm for a 1040mm ACME lead Screw?
    And just to let you know I don't have a computer hooked to my CNC machine. I am using Interface.
    But I can hook up black box to my computer and change GRBL settings.
    I checked my Y axis travel distance and it's off. Sent 28" =711.2mm actual distance traveled
    28.25 = 717.55mm. Off by 25.4mm.
    In black box it's set to $101 = 199.100mm
    So what's the math for setting this correct? I watched the videos and I'm still confused.
    is it 197.308?
    If its our Leadscrews, 199.1 steps per mm (Theoretical 200, but in practice the rolling process is a little off and its closer to 199.1)
    8mm pitch per rotation,
    1/8th microstepping of the BlackBox * 200 physical steps of the motor = 1600 microsteps per rotation.
    8mm per rotation at 1600 steps per rotation = 1600/8 = 200 steps per mm
    Rather than bothering to do the Math, just use the Wizard :)
    Use as long a distance as possible (the default 100mm is just a safe-ish suggestion to avoid crashes, longer distances = more accurate)
  3. jda70az
    jda70az Well-Known
    So 200*(711.2mm / 717.55mm ) = 198.23 ?
    Theoretically yes. Apply, reset the BlackBox, then test again
  5. jda70az
    jda70az Well-Known
    That worked. It's only off now by 1mm
    Thanks man you are super helpful.
    I remember now, you explained this to me like a year ago but I forgot. :banghead:
  6. David the swarfer
