GRBL error 30 on interface
Discussion in 'Interfaces' started by Ryan Joshua Gaines, Feb 6, 2023.
  1. Ryan Joshua Gaines
    Any idea why when i run G code on the Interface I get GRBL error 30, but when I run it from the PC it works fine? any thoughts?
    Is your Interface Firmware up to date? (V1.57)
  3. Ryan Joshua Gaines
    Please provide the gcode file
  5. Ryan Joshua Gaines
    here it is
    Thanks. The Gcode header doesn't contain any comments, out of which CAM is it?
    Which PC based host application do you use? OpenBuildsCONTROL or some other host>
  7. Ryan Joshua Gaines
    I use the Open Builds Control. Also when i ran the file on the Interface I Ran it Multiple times trying to get it to run, and the error occurred at different points each time i ran it
    Random position could be EMI: docs:blackbox-x32:faq-emi [OpenBuilds Documentation]
    If you use CONTROL, we don't modify the GCODE so if it really does run fine on CONTROL it should be fine on Interface too. Some other hosts do things like rounding decimals, stripping unsupported commands so just wanted to be sure
  9. Ryan Joshua Gaines
    thanks, ill give that a shot
