Can’t line up my Y bea
Discussion in 'CNC Mills/Routers' started by residentdj, Feb 11, 2023.
  1. residentdj
    So this was happening before, I took the whole thing apart to turn the Z beam around, so I pretty much pulled everything off and re-assembled and it still has the same issue.
    is one of my Y beams twisted?
    Ignore the squeaking noise. It’s the table making it. Not the machine.
    Streamable Video
    Unable to stream the video, but twisting in Y beam usually means the bottom braces arent passing past the beams as shown in the assembly video.
