Laserstorm S 10 laser has stopped working
Discussion in 'General Talk' started by RLB, May 18, 2023.
  1. RLB
    RLB New
    My new Laserstorm S 10 laser has stopped working, using updated GRBL program. All other commands work it even moves as if laser was working but not. I've checked all connections it all looks good, could it have something to do with GRBL because it worked fine on an engraving project I loaded.
    You can post the grbl settings if you'd like us to review it.
  3. RLB
    RLB New
    Thank you Peter, I received some help and replaced the wiring from my spare engraver laser it is working now....BUT , my X axis motor now vibrates ruining the engraving, should I just change the motor or is there another reason for the vibrating?
