Limit switch activated easilly
Discussion in 'CNC Mills/Routers' started by Wendel Clement, Jun 2, 2023.
  1. Wendel Clement
    Hello Openbuilders,
    I am having a strange scenario of the limit switch being activated and stalling my carving. This is happening when all of the gantries are no where near their limits. It always happens when I am vacuuming the chips. Perhaps if I hit one of the moving parts (usually gently).
    Does this make sense?
    Thank you.
  2. jeffmorris
    jeffmorris Journeyman
    The chips may stop the gantry from hitting the limit switches.
  3. Wendel Clement
    True but in this case there are no chips in the tracks, and it seems to only happen when I disturb it like touch one of the moving parts with the vacuum cleaner hose etc. If I stay away there is no interruption.
    Check out docs:blackbox-x32:faq-emi [OpenBuilds Documentation]
    Earth the vacuum hose to dissipate static
  5. Wendel Clement
    Ahhh interesting. My vacuum has a plastic hose which then extends into a metal one. I'll remove the metal one and see if it makes a difference.
    Thanks.
    Plastic is typically the problem. It needs earthing.. Refer the link provided above
  7. Wendel Clement
    Very interesting read. Funny enough I have an Electrical Engineering Degree (Many moons ago) and this hadn't crossed my mind, but once read it all makes sense.
