Limit Switch
Discussion in 'General Talk' started by kajlo30, Jun 8, 2023.
  1. kajlo30
    kajlo30 New
    Hello,i would like to use limit switch only on two axes X,Y.Is there a way to use two of them?Am using the black box controller.Thanks.
    BlackBox 4X : flash the 2-axes firmware from. Wizards and Tools > Firmware flashing tool
    BlackBox X32: define your homing sequences in Grbl Settings
    $44=3 ; Home XY together
    $45=0 ; Disable Z axis Homing
    kajlo30 likes this.
  3. kajlo30
    kajlo30 New
    Thansk sir,i will take a try.
  4. kajlo30
    kajlo30 New
    When i tried to flash i got the error msg Flashing error or something like that.
    But now i cant connect the usb to the controller.Cant make a connection.[​IMG] 20230608-121142 hosted at ImgBB
    You need to complete a successful flash. Try again
  6. kajlo30
    kajlo30 New
    I keep getting the FLASH FAILED error.I tried it at least 10 times.It was working perfectly til i tried to flash the controllet to 2axis machine without z homing.
    When i click on the flash button i see the usb logo on the blackbox is blinking.And then stops and i get the error message.
    Did anything happen like unplugging USB before it was done? Could have wiped the Bootloader? (You'll need a $3 USBTinyISP off Amazon to reflash the bootloader)
  8. kajlo30
    kajlo30 New
    The usb was not unpluged during the flash.
  9. kajlo30
    kajlo30 New
    Sir,is there any tutorial how to reflash the bootloader.Thanks.
    1) Grab a USBtinyISP from Amazon or similar
    2) Plug it into the ICSP port
    3) Arduino IDE > Uno > Flash Bootloader
    Same as this, but BlackBox instead of the Arduino (Open top cover of the BlackBox to find the ISCP pins)
  11. kajlo30
    kajlo30 New
    Thank you so much!
  12. kajlo30
    kajlo30 New
    By the way,maybe this is my problem?
    docs:interface:flash-run-jumper [OpenBuilds Documentation]
    i did not move the jumper to flash mode?
  14. kajlo30
    kajlo30 New
    Oh i see,my bad.
    You sure there're no wiring shorts that could have damaged the BlackBox - same symptoms, might just be coincidence around the time of flashing
  16. kajlo30
    kajlo30 New
    Just checked the cables,looks good to me.
  17. kajlo30
    kajlo30 New
    So iam done with reflashing the bootloader.After that the Blackbox flash was succesfull.Thanks for the help!
    Well done and Welcome Back!
    kajlo30 likes this.
