blackbox x32 power issues
Discussion in 'Controller Boards' started by Sapper73, Oct 28, 2023.
  1. Sapper73
    Sapper73 New
    I purchased my blackbox x32 on sept 25th 2023 I got everything installed and when I turn on everything on and blackbox did not power up. I check to see if i was getting 24v from the power supply and I was not, I was getting 120v AC. If I disconnect the 24v line to the blackbox I would get 24v on the power supply and 24v on the connector side while its not connected to the blackbox. As soon as I plugged it back in to the blackbox it would not get 24v while its plug to the blackbox. any help on this matter would be appreciated.
  2. Gary Caruso
    Check the 120-220ac switch on the side of the power supply
    Gary
    Post pictures of your PSU wiring please at PSU and BlackBox side for review
  4. Sapper73
    Sapper73 New
    I do have 120V power coming into the PSU no 24v DC output and the PSU is set for 120v and now 220v ac
    Pictures please, instead of videos. We just want to check the wiring itself quickly. Please follow instructions so we can help you sooner
    Will allow us to check for shorts and reversed polarity
  6. Sapper73
    Sapper73 New
    All is good Peter I sent an email with pictures and video to the support team they got it squared away for me. Thank you for your help kind sir.
