XYZ Probe Plus with VFDs and other ground-loop inducing components
Discussion in 'General Talk' started by juansierra, Apr 24, 2020.
  1. sergiomajluf
    sergiomajluf Well-Known
    I've had the sme issue since always, but learnt to live with it. Basically I unplug my VFD whenever I needed to probe (mostly in the middle of jobs, changing bits)... which is cumbersome and feels unstable, because every once in a while my controller crashes when doing this ... until...
    I just tried my very same cnc/controller/vfd/probe setup, except this time with my laptop, unplugged from the AC mains and voila!
    Time to get a USB optoisolator then.
    edit: BTW, and this might help other diagnose the problem. I had another issue, the trackpad of my cnc computer was unstable too. Didn't give it much thought asuming it was just "airborne" EMI from the VFD. Well, I just changed the laptop power supply's cable to an unearthed one, and problem begone. Time to resucitate my intent of having home swithces too!
    #61 sergiomajluf, Apr 12, 2022
  2. JonnyO
    JonnyO New
    I had the same problem with my XYZ probe using an HP SFF PC. When I switched back to an old Surface Pro 3 it had no problems at all. Picked up a USB in-line isolator and everything has been problem-free ever since.
    Thanks to everyone that contributed to this thread, most of all to Peter for putting up with all of us. :)
  3. Joe D
    Joe D New
    I have an X32 Blackbox that has similar problems. I have been using it for a few months now and it was all working fine. Now my XYZ Plus probe has the green LEDS on any time the ground wire is touching the spindle. I have disconnected everything from the Blackbox except for the Power plug, the Probe plug and the Computer connection to my laptop. If I disconnect the computer cord then the green LEDS go out. Im believing there might be a short in the Blackbox. I have also completely replaced every wire including the wires from the VFD, all the motor wires, all the limit switch wires and the computer connection wire. I had changed nothing from when it was all working and when it started failing.
    Thanks for any help.
    That rather indicates a short through the PC - try a different PC, or if the computer has 2-pin power plug - try flipping it around.
  5. Adam Jelinek
    I don't understand the grounding of ac and dc. With my spindle am I not to ground it to the vfd?
    Spindle should be EARTHED
    DC GND should be a seperate domain
    Having a short between the two (thats supposed to be isolated from each other - high voltage mains vs low voltage DC) is dangerous.
    Unplug things one at a time until probe (good test, could use a multimeter too but probe is a quick indicator of a problem) until problem clears up. Could be endstops mounted incorrectly, failing PSU in a desktop PC or Monitor, etc
  7. Adam Jelinek
    Unplugging the usb from my laptop turned the probe off. Unplugged each motor limits witch didn't change anything.
    Then laptop PSU might have a short. Try on battery only.
    Try flipping 2-pin plug on laptop PSU in socket (Neutral Earth bonds exists, if plugged in wrong way round it might leak current)
  9. Adam Jelinek
    The laptop only had a 2 prong plug. Will try battery only
    making it easy to reverse live/neutral, try plugging it in 180deg from current orientation
  11. Adam Jelinek
    It doesn't come apart at all. With it unplugged it still have the probe lights on. So I'm assuming a usb insulator would be needed. Now. With the vfd grounded to the outlet. Where would the proper place to ground the cnc it's self? Can I go to an outlet ground at well?
    #71 Adam Jelinek, Aug 27, 2024
  12. Adam Jelinek
    Issure resolved. Wasn't my usb. I had 2 limit switch grounding out through the bolt. Added a small plastic spacer and all is good
  13. Adam Jelinek
    Am I understanding this correctly. The ground for the spindle should be an earth ground and not a ground to the ground lug on the vdf?
    Confirm with your VFD and spindle vendor about specifics, but usually both spindle body and VFD has an Earth (connected to mains earth)
    Low voltage components has DC GND
    And DC GND should be perfectly isolated from Mains Earth
  15. Wackimac
    Wackimac New
    I am guessing I am having the same problem with my prob.
    I see steel rails, Z axis not isolated from frame like wheels would be so you have a wider area to check for DC GND (from say a limit switch) shorting to the frame or some other AC EARTH to DC GND short.
  17. Wackimac
    Wackimac New
    After check everything I found that I had a bad wire on my Y limit switch. It had a very low ohms reading between the red and black wires, Replaced wire and the XYZ prob work just fine. Also all limit switches as well work. This is my second machine I have build with OpenBuild and I am still learning. Thanks Doug
  18. ryana14
    ryana14 New
    I have this exact issue. Afer testing I found DC ground in the controller is connecting to Spindle Earth via the V- out from the CNC Controller (CNC4Newbie C4N controller, Openbuilds touch plate) to the ACM terminal (Analog Signal Reference: ACM acts as the common ground for analog inputs) on the Huanyang 2.2 KW spindle. This is wired as per instructions and works as it should, but please let me know if there is a better way to connect controller to VFD, see my connection below. The spindle is earthed back to the VFD so that completes the circuit and therefore the Probe PIN connects when the magnate is on the tool. (Edit: I think erroneous conclusion above).
    I swapped Signal and GND (blue with black) on the probe and now it works when the tool touches the plate, no need for the magnate.
    I have CNC Controller to VFD wired as follows.
    CNC Controller SP Relay + -------- FOR
    CNC Controller SP Relay - -------- DCM
    CNC Controller 0-10V + -------- VI
    CNC Controller 0-10V - -------- ACM
    The CNC Controller 0-10V terminal is continuous with the controller Probe - terminal
    #78 ryana14, Jan 14, 2025
  19. Peter Van Der Walt
    On VFDs the inputs like ACM is isolated from AC GND, so probably not via the ACM port
    Workaround fine, but there is still a short somewhere, i'd try fixing it before it causes damage
  20. ryana14
    ryana14 New
    Thanks for the reply, I just doubled checked with the multimeter, on my Huanyang VFD ACM is not continuous (multimeter does not beep) with AC ground on the VFD. I'll investigate further.
    #80 ryana14, Jan 14, 2025
  21. ryana14
    ryana14 New
    I think I found it.
    Testing continuity between controller DC ground to Spindle Earth.
    1: Controller Plugged in and VFD plugged in: I get Continuity, multimeter beeps.
    2: Controller Plugged in, VFD not plugged in. No continuity.
    3: Controller not Plugged in, VFD plugged in. No continuity.
    Is this a ground loop? Initially I thought impossible because my controller has no earth coming in, only the two 24V wires from the AC to 24 V DC power supply. The VFD is US/Canada (Three wires total, no neutral) 240 V with earth.
    I'm obviously missing something? Thanks for the help.
    #81 ryana14, Jan 14, 2025
  22. ryana14
    ryana14 New
    I solved the issue, my old power supply was connecting the DC Ground to AC Mains Earth, I connected a MEAN WELL LRS-350-24 350.4W 24V and the issue went away, I can now use the probe wired in the normal way.
  23. Peter Van Der Walt
    Oh yes please, not worth risking BlackBox on anything less :) - using different PSU can void warranty
    ryana14 likes this.
  24. Rune Leonhardsen
    Great thread!
    Openbuilds LEAD 1515.
    Before i had EMI problems with my Makita router. Got recommended to Ground the frame of the CNC to mains AC Earth, worked fine after that.
    But when i upgraded to a 1,5kW spindle with VFD, i got probing issues due to the steel body of the spindle that was grounded to mains AC Earth, didn't have that problem on the Makita router since it was not Grounded, only double isolated.
    But after reading through this thread i unplugged my limit switches and found the issue of the mounting screw shorting limit switch DC GND to the chassie, which again was Grounded to mains AC Earth.
    Mounted a nylon washer on the screw of the limit switches and everything was OK!
    Pretty green light when the bit touches the Openbuilds probe plate, just as it should!
    And everything wired as per Openbuilds instruction with no short between DC GND and AC Earth mains.
    Thanks to this thread it was easy to look for the root cause of the short.
  25. Rob Heckman
    Ok, so I am officially worried and not sure if I should be. I have a CNC4Newbie running a Huanyang VFD and 2.2KW Spindle. I have a star ground that goes to earth which is where my shield drain is for my cables (steppers, limit switches). My VFD is earth grounded as well. When I hook up my probe, the green light is lit and when the bit makes contact with the touchplate, it triggers and completes the probing sequence. This thread seems to indicate a grounding issue because I should not be getting and green lights until contact is made between the bit and the touchplate. Am I missing something?
  26. Peter Van Der Walt
    Shields can be Earthed - correct
    Spindle body should be earthed - correct
    DC GND just shouldnt be connected to AC EARTH
    Make sure none of your shields are shorting to any DC GND wiring
    Limit switch on Z maybe shorting to frame?
    Process of elimination: Unplug Endstops one by one. Unplug other things one by one. Even for example trying to unplug the HDMI monitor cable, see if the green lights go out.
    Somewhere there's a component (can be inside the PC or monitor for example - breakdown of PSU components) or a wiring mistake somewhere, or a mechanical component touching a terminal, carefully look around: Something is shorting AC EARTH to DC GND - when the short is removed, it will a) allow the probe to work and b) remove a rather dangerous fault from your system, if there is ever an electrical fault that has the Earth conducting high voltage, it can fry your low voltage electronics via the short, or even become dangerous to yourself
  27. Rob Heckman
    But the probe is working. It just has a low green light that when bit touches the touchplate turns bright green. If I disconnect my usb cable from X32 to my PC, the low green light goes away and only illuminates when I touch the touchplate to the bit (with power applied via a power supply). If I move the cable to another computer I get the same. If I replace the USB cable with a brand new one, I get the same. If I disconnect everything from the X32 except for the probe and the computer...I get the same. Probe functions but low green light until touch and the bright green light. Am I chasing my tail here?
  28. Peter Van Der Walt
    Low green light still indicates some leakage between GND and EARTH - so if it was mine, i'd still check to see where.
    But if it works, then I guess (until it doesn't anymore, if leakage increases it might get stuck in triggered state as soon as magnet clips to collet) its fine for now?
    Could be something like
    Probe clip > Spindle Body > Gets into mains earth > PC's PSU leaks a little current or some other fault where mains earth leaks to DC GND > gets into DC domain of the PC > Motherboard has a DC GND on USB port > Back to BlackBox to complete the circuit, but high enough resistance that it doesn't trigger, just enough that the LEDs glow
  29. Rob Heckman
    Ill keep looking but im running out of options. I have completely replaced the PC and unplugged everything from the controller and getting the indication.
