Technical Data for V-Extrusions
Discussion in 'General Talk' started by micke45, Mar 27, 2015.
  1. micke45
    micke45 New
    does anyone know were to find technical data like cross sectional area, cross sectional momentum and resistance? I am also interested in the exact measures of the profiles (maybe in a pdf format). I found some pictures, but they were hard to read.
    Thanks in advance for your help
  2. Rick 2.0
    I can't help with the first part of your question but you can get more readable dimensions and a model from the Sketchup file posted here. Note on the dimensions and model, the small triangular voids at the corners of the V-slot sections no longer exist as all current production stock has the corners filled in solid.
