Can not acces jog site
Discussion in 'General Talk' started by Jessep, Oct 2, 2024.
  1. Jessep
    Jessep New
    few days ago it worked ok.
    What could I do ?
    169.254.x.x looks like an APIPA address, What is Automatic Private IP Addressing (APIPA)?
    You need to make sure your network / DHCP is working right - APIPA is indicative of a non working or badly setup network. Likely phone has a proper IP (seperate route from APIPA) so won't see the PC
  3. Jessep
    Jessep New
    Ok kind thanks, could You give some advice / ytube link to do this with iPhone?
    As said few days ago I was able to use the phone as a pendant
    Not the phone side... The PC doesn't have a valid IP (usually more like 192.168.x.x or 10.x.x.x for consumer stuff) try a reboot, make sure PC is on the network
  5. Jessep
    Jessep New
    Thank You, worked!
