Tall OX
Discussion in 'CNC Mills/Routers' started by Gabriel Faber, Jul 16, 2015.
  1. Gabriel Faber
    Gabriel Faber published a new build:
  2. Doug Wilson
    Nice build! I'd love to know more about your spindle.
  3. Gabriel Faber
    I just uploaded the DXF file for the spindle.
    The base design is by Robert Hummel (See "890KV OX RC spindle" in "Other builds"). I shortened the mount somewhat and added stubs for alignment to the Z-axis profile.
    The speed controller is a NEEWER Mystery Fire Dragon 80A Electronic Speed Controller (ESC) from Amazon. To control it from Mach3, I added a Arduino Nano with a program that converts PWM (from Mach3) to PPM (What the ESC needs)
    I run it at 12 Volt, which gives me a maximum speed of 11000 RPM
    I've been cutting wood, plastic and aluminum (mostly 1/8" end mill)
    Rhenway, Doug Wilson and GrayUK like this.
  4. Justin Dewoody
    Where did you get the acrylic drag chain? Or did you make it yourself? I really like that!
    Justin
  5. Gabriel Faber
    I added a design image of the drag chain and uploaded the .dxf file (I tried the original .svg file, but it would allow me)
  6. nate campbell
    Looks great, I also went for taller plates as I wanted to be able to mill 2" XPS foam with a 2" bit. Waiting on the final parts to start my build.
  7. pizzaman85
    this looks like a great build. very nice. i found the gantry plates looked like a great idea also but i downloaded the dxf files but they did not work for me. i think they would work better on the ox that i have built. any help would be greatly appreciated. thanks
  8. Mark Carew
    Well done @Gabriel Faber ! This is a great looking Build :thumbsup: Thank you for sharing
  9. Gabriel Faber
  10. Gabriel Faber
    Hi pizzaman85,
    What was the problem with the DXF files?
    I downloaded the file and opened it in Inkscape 0.91 without problems
    Note that it is scaled in millimeters
  11. Rick 2.0
    Gabriel, AutoCAD 2008 gives "Invalid or incomplete DXF input -- drawing discarded". Autodesk TrueView 2014 has no problem with it. So it is clearly a software dependent issue.
  12. Gabriel Faber
    I exported the DXF files from Autodesk Inventor in the 'AutoCAD 2013 DXF' format
    If anybody wants a different format (Inventor lists AutoCAD R11, 2000, 2004, 2007, 2010 as other DXF options. It also supports PDF, JPEG), let me know
