Project Openbuilds / Open Hardware Keychain 2016-03-03
Keychain so you can represent the openbuilds and open source hardware logo next to your keys.
  1. Kyo
    Kyo Veteran
    Kyo submitted a new resource:
    Openbuilds / Open Hardware Keychain - Keychain so you can represent the openbuilds and open source hardware logo next to your keys.
  2. Mark Carew
    Kyo these are awesome! Thank you for sharing :thumbsup:
    Hope you don't mind, I added a few files to try and help.
    Gcode - some of my standard settings
    STL - for anyone wanting to 3D print it
    Sketchup with the worked part in SketchUcam
  3. Kyo
    Kyo Veteran
    Thank you, Happy to share. I don't mind at all, those are great additions.
  4. Mark Carew
    Kyo and eddiejr like this.
  5. Kyo
    Kyo Veteran
    Awesome, it looks great ! I have to grab some acrylic to mess around with...
  6. Davus
    Davus New
    Hi Kyo,
    I've yet to carve my first item. I have a few bits ready to use when the time comes. Can I ask what kind of bit you used for your aluminum version?
    Thanks,
    Davus
  7. Kyo
    Kyo Veteran
    Hello Davus,
    Here are the details I used to cut the Aluminium version.
    16,000rpm
    40ipm
    0.015" depth of cut
    40% Step over
    Endmill used was. 1/8" flat nose single flute upcut carbide
    jctb2 likes this.
  8. Davus
    Davus New
    Thanks, now for some aluminum.
  9. Sonny Lowe
    Sonny Lowe Journeyman
    Kyo,
    Love this project!!! Any chance you could export this file in a step format or anything else that might work in Solidworks!?!?
    Thanks,
    Sonny
  10. Kyo
    Kyo Veteran
    @Sonny Lowe Thanks, Sure no problem. I went ahead and redrew this Project in Fusion 360. Some of the arcs differ from the first iteration otherwise same design. Here is a Step export as well as the source Fusion archive file.
  11. Sonny Lowe
    Perfect...thank you :)
