Laser engraver
Discussion in 'Laser Cutters' started by Anthony Bolgar, Nov 28, 2016.
  1. Anthony Bolgar
    Anthony Bolgar Journeyman
    Surgtek and Derekz like this.
  2. MaryD
    MaryD OpenBuilds Team
    Following. :)
  3. Mark Carew
    So true :thumbsup:
  4. Tracy Ranson
    Tracy Ranson Well-Known
    Since you are not using aluminum plates I would recommend that you use .250 or .375 thick acrylic which should be more than strong enough to hold a laser and the aluminum rails, but if you make the foot print too large you will need something a bit stronger to hold up the gantry.
  5. Anthony Bolgar
    Ya, I decided to use 6mm (1/4") acrylic for now, if I ever add a small spindle, I will upgrade them to aluminum.
  6. Anthony Bolgar
  7. MaryD
    How did your plates turn out?
  8. Anthony Bolgar
    Went back to 1/4" acrylic plates, not happy with the 3d printed ones. Need to find some time to finish this project, just the wiring left to do.`
    MaryD likes this.
  9. Muralikrishna
    did you finish the project ? did you use nema 23 or 17 ?
    if its finished can you share me some pic
  10. Anthony Bolgar
    I have all the mechanicals done, and am in the process of wiring it up. Should have some pics of the finished machine in a couple of weeks. Will be posting all the files and a BOM as well.
  11. Muralikrishna
    what motors you used nema23 or Nema17
  12. Anthony Bolgar
    I used Nema 17 motors, there is not much weight to move around.
  13. Muralikrishna
    i am looking for nema23 do you have design ?
  14. Anthony Bolgar
    I can redo the plate drawings for a nema 23 motor. Give me a couple of days.
  15. Muralikrishna
    OK sure can i have your Email ID
  16. Anthony Bolgar
