OpenBuilds ACRO Laser System
  1. omar411
    omar411 New
    And how can i install my machine setting on grbl
  2. omar411
    omar411 New
    Is it will differ if i use arduino mega ?
  3. pedrofernandez
    pedrofernandez Journeyman
    nop just select the proper card in the arduino software, use the grbl panel to enter all the machine parameters gerritv/Grbl-Panel
  4. omar411
    omar411 New
    sorry sir but the last question , what is grbl panel ? and thanks a lot for your help .
  5. omar411
    omar411 New
    And how to use it
  6. pedrofernandez
  7. Scotty Orr
    Scotty Orr Journeyman
  8. omar411
    omar411 New
    Alot of thank
  9. bekindr
    bekindr New
    The problem is that I'm powering the xpro with an atx power supply so I I'm not sure how wiring that could work... I've already wasted over $800 on this thing so I should have just bought a pre-built laser engraver =/
  10. cathode
    cathode New
    So I just put together my ACRO 40x20.
    I have a whole extra 4" double extruded aluminum beam, that I don't know what to do with. It's not in the build video. It has a 9.5" piece of rubber slot strip in it. Does anyone know what that's for?
    I also have a fair amount of screws and a little bag of angle brackets left.
    #310 cathode, May 5, 2018
  11. Kyle Poniatowski
    Hello, I've assembled my ACRO and it is awesome, I have the laser powered up with a power supply and my PWM PIN attached to the cancelled shield. I have not been able to get grbl to turn on the laser. I've used the commands to turn the laser on m3, just to try. I have been looking at all the wiring diagrams but I think im missing something.
    Does anyone run a 3.5w 3 wire chinese diode that can help me hook this up properly? I am using an Arduino uno with a v3 cnc shield in laser mode. And help would be appreciated.
  12. pedrofernandez
    Buy this https://www.amazon.com/gp/product/B00CHTLAIS/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 then ill help how to wire it up that is your missing link
  13. Kyle Poniatowski
  14. Kyle Poniatowski
  15. dangerousderek
    I've seen a bunch of projects posted on openbuilds where people are routing out the brackets for the ACRO system, but I can't find where/if the DXF files are provided anywhere. I would like to build an ACRO, but I thought since I already have a CNC I could save some money cutting the brackets myself and then just buy the hardware from openbuilds. Am I missing something? Thanks!
  16. pedrofernandez
    your power supply is the same for the machine and the module?
  17. Kyle Poniatowski
    It can be... I have both available.
  18. pedrofernandez
    https://openbuilds.com/attachments/openbuilds-acro-laser_v2_dxf-dxf.31727/
    dangerousderek likes this.
  19. dangerousderek
  20. pedrofernandez
    both are 12v or 24 for the machine and 12 for the module
    try sketchup
  21. omar411
    omar411 New
  22. omar411
    omar411 New
  23. Giarc
    Estlcam will also open dxf files. It can then make the gcode for grbl which can be used with any grbls sender such as grbl panel. I just use Estlcam for both cam geberation and controlling my cnc router now.
  24. Steven Bloom
    Steven Bloom Journeyman
    I have a question. How fast does that carriage move. Example , can it move 1000mm per sec or something else ???
  25. pedrofernandez
    recommended settings:
    $0=10 (step pulse, usec)
    $1=255 (step idle delay, msec)
    $2=0 (step port invert mask:00000000)
    $3=6 (dir port invert mask:00000000)
    $4=1 (step enable invert, bool)(Board V1, V2, V3 Matte = $4=0 - Glossy board V3 = $4=1)
    $5=0 (limit pins invert, bool)
    $6=0 (probe pin invert, bool)
    $10=0 (status report mask:00000010)
    $11=0.020 (junction deviation, mm)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $20=0 (soft limits, bool)
    $21=0 (hard limits, bool)
    $22=0 (homing cycle, bool)
    $23=1 (homing dir invert mask:00000000)
    $24=25.000 (homing feed, mm/min)
    $25=500.000 (homing seek, mm/min)
    $26=250 (homing debounce, msec)
    $27=1.000 (homing pull-off, mm)
    $30=1000 ($30 - Max spindle speed, RPM)
    $31=0 ($31 - Min spindle speed, RPM)
    $32=1 (Laser mode, boolean)
    $100=114.290 (x, step/mm - 1/16 step - Set this according to your boards step setting)
    $101=114.290 (y, step/mm - 1/16 step - Set this according to your boards step setting)
    $102=114.290 (z, step/mm - 1/16 step - Set this according to your boards step setting)
    $110=10000.000 (x max rate, mm/min)
    $111=10000.000 (y max rate, mm/min)
    $112=10000.000 (z max rate, mm/min)
    $120=2000.000 (x accel, mm/sec^2)
    $121=2000.000 (y accel, mm/sec^2)
    $122=2000.000 (z accel, mm/sec^2)
    $130=1000.000 (x max travel, mm - Set this to your machine safe cut area)
    $131=1000.000 (y max travel, mm - Set this to your machine safe cut area)
    $132=1000.000 (z max travel, mm -Set this to your machine safe cut area)
  26. Steven Bloom
    while those settings look great. I am wondering if someone is actually able to run the acro safely at 1000mm per sec.
  27. Scotty Orr
    So you are asking if it will safely run 6 times the recommended max rate, correct?
  28. Steven Bloom
    I was just asking what the normal max speed was. So I guess its around 200. That answers my question
  29. cathode
    cathode New
    hello - can you post a diagram or simple explanation to how you have the bulbs set up? I'd like to do this too.
  30. cathode
    cathode New
    So I've read 1000 different safety manuals and they all agree that you shouldn't look at the dot your engraver makes, even with safety goggles on. I'm trying to focus my laser diode and can't figure out how to do that, or monitor the engraving - except by setting up a video feed (which I'm looking into.)
    Is it true that you can't look at a laser's dot even with googles?
    I have a pair of $60 OD6 goggles. thinking about returning them in exchange for a raspberry Pi video feed.
