Materials Speeds and Feeds Chart
Great speeds and feeds chart for 1/4" milling of lots of materials
  1. Mark Carew
    Mark Carew submitted a new resource:
    Materials Speeds and Feeds Chart - Great speeds and feeds chart for 1/4" milling of lots of materials
  2. GrayUK
    I need to remember it's there!! :banghead::thumbsup::thumbsup:
  3. Mark Carew
    I print out these kind of charts and have them next to the computer where I do the toolpathing, so I can glance over and have the info needed while working. Really is a big help :thumbsup:
    Edgar Stanbury and GrayUK like this.
  4. Giarc
    It was nice of them to include the Makita as well. I was just getting ready to make the conversions when I noticed it was already there.:thumbsup:
  5. Miles Gregson
    This is great, thanks!
    A dumb question, is the feed rate inches/minute? I'm UK based.
  6. Mark Carew
    The feed is in inches/minute
  7. Naiggel
    Naiggel New
    That's really helpfull!! I will print it also. (I own a workbee 1510)
    You say inches...If I give in artcam 65 feed and 25 plunge, which by the way I use mm, for milling acrylic is going like crazy. If I have to give inches I'm expecting flying like superman. :jawdrop::eek:
    Do I read it wrong? Sorry for my english and my noobidity. I'm new in cnc world. :(
    And what is the Doc category?
    Thanks!!
  8. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    @Naiggel DOC = Depth of Cut. Means how much the Z axis will go down per each pass
    Naiggel likes this.
  9. Naiggel
    Naiggel New
    Thanks Ariel!!
    Can you tell me about the feed and plunge?
    For example...for acrylic it says feed=65 and plunge=25 with speed 19000. Is that ok? Cause I'm little "scared" to put these on my machine. (or just noob):D
  10. Naiggel
    Naiggel New
    ok..I just did it...not bad at all.
    Thanks for your I answer.:thumbsup:
    Ariel Yahni likes this.
  11. Ariel Yahni
    @Naiggel Be cautios of that information and always test if you are not sure. You can always speed up / down if you are using for example the OpenBuilds Control
    Mark Carew and Naiggel like this.
  12. Naiggel
    Naiggel New
    Yeah I know...and yes I'm using OpenBuilds Control. Thanks!
  13. Alex Chambers
    If it helps I have put a copy of that table in helpful tools with the conversions to mm/minute done. It's title is "speeds and feeds". Alex.
    Naiggel likes this.
  14. Naiggel
    Naiggel New
    thanks Alex, I think I understand now some things. I can't put the conversion from inches to mm!!
    I dont know why, but ArtCam have two different systems!
    When I choose bits with inches, feeds and plunge are in inches/min but when I use metric tools have mm/sec.
    Imagine putting 1651mm/sec!!!:banghead::banghead::banghead::cry::cry::cry:
    I don't know if there is something I can do to change that to mm/min!
    For now I will continue adding and trying with inches tools and will see!!:) (or devide feeds and plunge mm convertion with 60:thumbsup:)
    #14 Naiggel, Feb 7, 2019
  15. Mark Carew
  16. wTWiddlX7e
    I wanted something better than a printable version of this, if only so that I could add to the list with other materials. So I've converted the image into a spreadsheet version with the same data, and added a few columns to include the equivalent metric values and a few columns to interpolate the recommended dial settings for the DeWalt and Makita routers into RPMs (e.g. Dial value 1.5 translates to → 17250RPM). Feel free to change the Dial settings, and the spreadsheet will calculate an approximate RPM. For example, changing the Dial value to 1.24 would yield 16860 RPM. Not sure why anyone would WANT to calculate something other than was recommended, but there it is.
  17. Mark Carew
