Licensing for solidworks files?
Discussion in 'OpenBuilds Bug Report' started by mirage335, Jan 7, 2014.
  1. mirage335
    mirage335 New
  2. Mark Carew
  3. mirage335
    mirage335 New
    Thank you. Will the following text in a license.txt file stating the following comply with the license?
    Files in this folder were originally obtained from http://www.openbuilds.com/ at http://openbuildspartstore.com/motor-mount-plate/ . They, and all modifications to them, retain their original license, unless a different license is noted in their file.
    Open Builds staff have stated
    " The motor mount plates are licensed under the creative commons CC-BY-SA
    More info here http://www.openbuilds.com/threads/openbuilds-creative-commons-licenses.57/ "
    http://www.openbuilds.com/threads/licensing-for-solidworks-files.276/#post-850
    Additionally, I have provided the legal code in plaintext in a file named "Creative Commons Attribution-ShareAlike 4.0 International license.txt" .
  4. Mark Carew
    Here are the allowances and requirements of the CC-BY-SA license.
    You are free to:
    • Share — copy and redistribute the material in any medium or format
    • Adapt — remix, transform, and build upon the material
    • for any purpose, even commercially.
    • The licensor cannot revoke these freedoms as long as you follow the license terms.
    Under the following terms:
    • ShareAlike — If you remix, transform, or build upon the material, you must distribute your contributions under the same license as the original.
    • No additional restrictions — You may not apply legal terms or technological measures that legally restrict others from doing anything the license permits.
    More Info: http://creativecommons.org/licenses/by-sa/4.0/
    Its a pretty straight forward license and very open to use :)
    Hope this helps
  5. mirage335
    mirage335 New
    Right, just wanted to make sure the license.txt file complied with that license. Thank you.
  6. Mark Carew
    Ahh I see :) Looks good to me @mirage335
    BTW Your FlexReplicator, is one cool machine that can do it all! Looking forward to seeing this one come to life.
  7. mirage335
    mirage335 New
