G-code to xyz positons
Discussion in 'DrawBot' started by SamFlynn, Dec 1, 2019.
  1. SamFlynn
    SamFlynn New
    Hey guys,
    Hope you all are doing well.
    Firstly forgive me if this is not he place to post this.I am a somewhat new to this cnc thing and probably answers already posted elsewhere ,but i feel so lost.
    So I built a 5 bar linkage mechanism using arduino and python.It uses 2 servos, an arduino mega, a 12v power supply,a dc-dc step down converter to power everything.
    The arduino's job is to to take two angle input in a csv format via usb serial input and rotate the servos to that specific angle.
    The python script's job is to take a xy input in csv format via terminal and calculate the two angles using inverse kinematics so that the end-effector reaches the desired xy position and send them to the arduino via serial.
    I have been seeing a lot of pen plotter videos recently and saw almost all of them use grbl and universal g code sender.
    What i want to do -
    So is there any scripts or something related which takes G-codes as input and outputs XYZ position of the toolpath in correect sequences so that
    I can just input those sequences in my python code to get the plots hopefully?
    There should be existing "gcode parsers" for python. Check the usual repositories. I am not sure what those are for Python, if you were using nodejs i'd point you to the NPM repo keywords:gcode - npm search (Surely you python guys have a similar home to call home? Pip wasnt it?)
  3. SamFlynn
    SamFlynn New
    Thank You for your response,looking into pygcode module and the NPM repo
    -it is pypi :D
    Sweeet! :)
    ahh yes: Python Package Index (PyPI) vs Python Package Manager (pip) lol!
