The Merry Mail project consists of two files – one that is the base (female) part of the sign that contains a pocket to create a border effect and another file that is the female inlay for the merry mail text. Cut the Merry Mail – Male file first – that way you have the male part ready to check the chalkboard fits into the female pocket inlay of the Christmas Countdown File. When cutting the Female Pocket inlay check that the male part fits in snug – if it doesn’t you will need to add/increase the negative allowance to overcut slightly to ensure you have the perfect fit. (Refer to the video for more information on this)
- Vectric
- Machine Time:
- < 1 hour
- 0.25" End Mill
- Feeds & Speeds:
- Various
- Ply wood
Note: When creating inlays you need to make sure that you use the same tool for both the Male and Female Parts.
Once everything is cut – simply paint up the parts, attach the flush mount to the back of the sign, attach some eye hooks to the bottom of the sign, tie in some string and then peg up your cards!
Here is the video for the Project!
I have attached a zip file which includes two sets of files to make this super easy to machine. The first set
contains the vectors and toolpath information ready for you to output the toolpaths, for this option, you will need
to either own Vectric software or download the FREE trial software, where you will be able to output the gcode
for this project. You can download the Trial software here.The second set includes the vectors for you to use in your own CAD/CAM software package.
Happy Making
rokasni likes this.
