Axis's not reversing!
Discussion in 'CNC Mills/Routers' started by msmuggs, Oct 22, 2023.
  1. msmuggs
    msmuggs New
    Re-did my wiring setup and now my y axis won't reverse. I have tried everything I know but still doesn't work. Marked all my wire positions before new setup. Using a Lanyee controller with a DM860 power supply with a Wantai 42 motor. Any help would be greatly appreciated.
  2. Gary Caruso
    Are you saying no matter what way you command it only moves one way? is the movement smooth or erratic?
    Most likely the dir signal wire is broken for Y. If it's erratic then one of the 4 wires to the motor is loose
    Or if you mean it's just going the wrong way opposite command but working in both directions then you need so swap the polarity of a motor coil around.
    Gary
  3. msmuggs
    msmuggs New
    Thanx, I'll check it out.
