Back to 4th axis questions
Discussion in 'Controller Boards' started by slc63, Jan 31, 2024.
  1. slc63
    slc63 New
    Okay, I've got all axis' turning and burning. New problem, no matter if i set up the file for x or y center the x axis motor turn instead of the A motor when using openbuilds control. what am I doing wrong?
    Which CAM? Which Post Processor?
  3. slc63
    slc63 New
    If I understand you right, I am using Vetric aspire making a rotary file and saving the file as a openbuild gcode. I also set all my zeros with extra tolerance to test it but it want's to dive too deep in the material along with not moving the a axis.
    Standard post is XYZ only (for years Vectric allowed wrapping around X or Y, its really a 3-axes CAM, not full on 4th like Fusion etc)
    Vectric's wrapping feature will output X or Y coordinates for the Rotary by default.
    You can copy and edit the Post Processor to output A-axes commands instead, or find/replace the commands in the gcode: One user reported that to be his trick
    @Giarc might know of a premade Post that does A (The demon rotary one is XYZ only too?)
  5. Giarc
    I only know of the Rotary Demon Post Processor. Sorry.
