Running a small test piece on a diy CNC plasma through CONTROL with a blackbox x32.I’m having an issue where I run the job and after the torch is moved to the first location for a pierce its not waiting for the .6 seconds I have it pause in the gcode. I’ve noticed in the first few lines of the gcode that it mentions (Laser UsePierce) and it’s set to false. Is there a setting in post processing that I’m missing? (Made in : Autodesk CAM Post Processor) (G-Code optimized for Grbl 1.1 / BlackBox controller) (OpenBuilds CNC : GRBL/BlackBox) (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.33) (Units = inch) (Laser UseZ = true) (Laser UsePierce = false)
