Cutting HDPE
Discussion in 'CNC Mills/Routers' started by BeeAMaker, Dec 26, 2020.
  1. BeeAMaker
    BeeAMaker Well-Known
    Looking for advice on speeds and feeds for a clean cut on HDPE.
    My current settings are fairly smooth but looking to improve it.
    1/8" 3 flute TiCN coated carbide (also tried 2 flute, cuts about the same)
    Spindle Speed 32K
    1800 mm/min
    Multiple pass @ 1mm per pass
    These are pretty much the defaults Fusion360 put in with the tool specs and spindle speed. I've adjusted them a bit from that but not really sure what I am doing yet. I have since found this calculator and wonder if I should go by it.
    Fablab Feeds and Speeds Calculator
    Any advice would be great, thanks!
  2. sharmstr
  3. BeeAMaker
    Awesome, thanks!
  4. BeeAMaker
    After looking at and trying several other suggestions, this is what I came up with.
    1/8" 1 Flute HSS.
    Spindle Speed, 18800 (#3 on Router11 calculated 10K - 32K, 4400 per switch setting 1=10000, 2=14400, 3=18800, 4=23200, 5=27600, 6=32000)
    Feed: 1746 mm/min
    DOC: 1.95 mm
    Gives a nice smooth finish, no chatter rough cut, no finish cut.
    Note you can also achieve half settings on the Router11 1.5, 2.5, 3.5 etc
    I also found this generic Feeds&Speeds calc a big help.
    Hope this helps someone. Thanks!
    Giarc likes this.
