freezing up when I load a job
Discussion in 'Control Software' started by Daniel Smith, Dec 20, 2024.
  1. Daniel Smith
    Why does openbuilds control freeze everytime I load a job, Every single time, Doesnt matter the size of the file, As soon as I hit load job, It freezes, Ive turned off and on all the 3d viewer options etc.., Nothing fixes it, Any suggestions?
    Where is the gcode from? (What CAM application, sure its the correct post/dialect?)
    Please provide a gcode file for review
  3. Daniel Smith
    I use fusion 360 for cad and cam
  4. Daniel Smith
    I have tons of other examples, I have a lead1515 machine, Im using the correct post processor as far as I know
    Your post processor is a little outdated (should be on v1.42) but should load as gcode.
    So next question tried a different PC yet?
  6. Daniel Smith
    I have not, but thats a pretty capable laptop, I run fusion 360 pretty well on it, Ive been using cnccomander as control software and it works fine, loads up gcode instantly, I just like openbuilds better if i can get it working
    Well please do, just a comparison test to see - should work.
    Your CONTROL is up to date right (v1. 0.388)
  8. Daniel Smith
    yes running v1.0.388, I really need it to work on this particular laptop lol
  9. Christian James
    Christian James Journeyman
    Peter, I'm no g-code expert, but why does the tool dive down right at the start?
  10. Daniel Smith
    I'm not sure if the gcode is showing that, but that does not occur in reality, I've ran this particular code numerous times, tool goes up and moves to first operatiin position
  11. Peter Van Der Walt
    Its in G53 (lifts up to couple mm short of Z homing switch, switch trigger point is 0, machine itself is all negative quadrant. Read Frequently Asked Questions)
  12. Peter Van Der Walt
    Regardless, please do the test, so we eliminate other non-PC causes from the test. If it also fails on the other one --- then its NOT that laptop :) but until you test, we wouldnt know :)
    I mean, it loads fine here, so the gcode is OK, so we gotta push onto next thing (and if that doesnt reveal anything we move onto step after that) till we find what it is that causes the issue for you.
  13. David the swarfer
    because the viewer does not draw the G53 moves correctly.
  14. BillyTheClown
    after upgrading - my machine also freezes, hitting pause then run allows it to continue for a short time, the freezes again -
    backing out the install, I use aspire to create my gcode
  15. BillyTheClown
    I reinstalled v1.0.136 - ran the same gcode file with no pause. The only issue I had was the zero for xy was off. Used the probe to zero for both runs, but for some reason the xy was off so far off that the second run did not match the first run and the work piece was not usable. To the store tomorrow to buy more wood.
  16. Peter Van Der Walt
    What machine/controller are you running?
    If its not a grbl/grblHAL based controller it won't work with the newer stuff. V1.0.136 is suuuuper old Release v1.0.136 · OpenBuilds/OpenBuilds-CONTROL from January 2019! But did support other types of firmware back then. So maybe you have a controller from back in those days?
  17. BillyTheClown
    lead 1010 with X32 - strange thing I reinstalled v1.0.388 - removed the bit, and ran it, no pause
    will do more testing this week
    #17 BillyTheClown, Dec 22, 2024
