Mesuring Probe
Discussion in 'CNC Mills/Routers' started by Marco68, Nov 6, 2024.
  1. Marco68
    Marco68 New
    Hello everyone
    I would like to know if it is possible to connect a 3D part measurement probe to a black box?
    I would like to find the high point of a piece by measurement.
    If possible, how do I go about creating a macro that will scan the entire surface and give me the X Y coordinates of the highest point?
  3. Marco68
    Marco68 New
    Many thanks
    The goal would be to create a parameterized program with the max dimensions in X and Y, the “theoretical” height. I'll have to get into javascript programming...
  4. Marco68
    Marco68 New
    With the 3D part probe, I would like to find the high point of a piece by measurement. for surfacing a slab for exemple
    The goal would be to create a parameterized program / macro with the max dimensions in X and Y, the “theoretical” height.
  5. Misterg
    Misterg Veteran
    Have a look at bCNC - it has a surface probing routine built in, and can auto-level to a probed surface.
    GitHub - vlachoudis/bCNC: GRBL CNC command sender, autoleveler and g-code editor
