No option to export from CAM to Control
Discussion in 'CNC Mills/Routers' started by WoodworkerSD, Mar 20, 2024.
  1. WoodworkerSD
    I create my toolpaths but I am unable to connect with Control to export. I have the most up to date control but doesn't give me the option.
    Follow the onscreen instructions where the old button used to be.. Video is a couple years old
  3. WoodworkerSD
    There are no instructions where the old button used to be. I put a screenshot on my original post. All it says is save the Gcode to the computer and open it in control. Also, I am unsure what video you are referring to.
    Correct. As you would with any CAM. Create GCODE > Save it
    Then go to CONTROL and open it.
    I think about the only place the Transfer button / CONTROL integration legacy still lives on is the the old Hello World video? Or where else are you expecting to see the Transfer button from? (Its been removed for a long time in favour of the more standard Save/Open workflow)
    docs:software:overview [OpenBuilds Documentation]
    Nice seperate silos (CAD > CAM > CONTROL) with flexible options in each. Save and then go and open is pretty standard way to use a computer and access files between different applications
  5. WoodworkerSD
    Ok. I didn't realize that it was taken out on purpose. I really miss it but makes sense.
    CAM > Settings tab > Changelog button to see what's changed when
